Posted (edited) · How do you edit GCODE?
I recently saw something about how to edit your print settings so after the print is finished the 3d printing extruder moves to a certain coordinate and therefore triggers a noise to tell you that your print is done, the video is here:
  I was wondering is this possible to do in cura?
I'm sorry if this is a dumb question, I'm new to this 3d printing thing....
Edited by TomRiley
misspelling
    Posted · How do you edit GCODE?
    If you want to change the behavior at the end of the print-job, then the End G-code section in Manage Printers (or the Printers pane of the Preferences)-> Machine Settings is the best place.
    If it is only for one print (e.g. to test it), you could manually edit the gcode-file in Notepad, Notepad++, or a similar plain-text editor.
    But be aware that if you insert wrong codes, you could make the head crashing into things and damage it. Or you could burn the plastic in the nozzle by heating it too hot for too long.
    M300 is the Marlin Beep command (very annoying) for the speaker on the printer only.
    For a remote system (as in the video) you would need to design the bracketry for the switch and any other thing that might be required.
    Much depends on your printer.  Whether it's a bed slinger, a fixed bed, or a delta would determine:  which axis you want to use to trip the switch, the placement the design of the bracketry, and possibly a trip dog for the switch.
    Then the End Gcode would be adjusted to tell the printer to move an axis to the switch.  It might have to pause for a second or two and then move away from the switch so as not to keep leaning on it.
