Is the "start/end gcode" tab still in Cura? I'm not seeing it in 14.07
It definitely is.
Start/End gcode in Cura is only available when it is configured for normal gcode output. When set up for the Ultimaker², it isn't there, because all the start and ending stuff is done in the firmware.
Just learned this reading through the manual again. I have an ultimaker2 so that explains why I'm not seeing it.
gr5 1,968
In Cura there is a tab called "start/end gcode". You can add your own codes in there and they will get added to the final gcode file.
Or you can use prontrface to send them directly/manually.
