M code
tommy-gunn
In Cura there is a tab called "start/end gcode". You can add your own codes in there and they will get added to the final gcode file.
Or you can use prontrface to send them directly/manually.
    • 6 months later...
    Just learned this reading through the manual again. I have an ultimaker2 so that explains why I'm not seeing it.
