Yes there could be a small difference between the beginning and the end, but not so much as when you level with the cold nozzle and print with the hot one. And additionally a hot print core is needed to soften any filament residues on the tip of the nozzle.
Heating up a print core is quite fast, the time you notice after leveling and before starting the print is the print bed which takes much longer to heat up again and which is also turned off during leveling to avoid electrical interferences.
1
Smithy 1,132
The reason why the heater is turned off before leveling starts is that there are many interferences from the heater that could cause a leveling error.
arj3090 2
Would it be better to not heat the print core before leveling? If the core is at temperature on the first touch off point and cool for the last, I would have to guess there is a small amount of thermal expansion/contraction creating some inaccuracy in height measurement.
