I have the same priblem. 3mf attached.Inside Supports problem.3mf
GregValiant 980
When I slice it I'm not seeing any problems. Can you post a screenshot of the problem layer(s)?
EDIT: There is a bug report on Github #11258 regarding this sort of behavior. What operating system are you using on that computer?
Edited by GregValiantHere is a screenshot of a preview from 4.12.1:
And here, same model and all other settings, profile, etc. on 4.13:
Note the supports inside the model circled in red and the supports off the build plate circled in purple (I made a different post about this).
This is Ender 3, Windows 11. Note that I see a lot of strange things with my CAD programs on Windows 11 (OpenSCAD won't even run without hanging), but I haven't had a problem with Cura before 4.13...
GregValiant 980
There is a backlog item for this.
GregValiant 980
This has come up before. I can't remember if it got figured out or not. With that model loaded in Cura and with Cura set up and ready to slice use "File | Save Project" and then post the 3mf project file here.
