6 hours ago, Carla_Birch said:Do you have anything like a craft knife that could fit in the gap and let you cut the filament where it enters the printcore?
You could then remove the bowden and remove the broken filament from it and then try running the print core cleaning to see if you can unblock the print core, you might need to also get some nozzle cleaners the right size of the nozzle and try pushing them up the nozzle when hot from the underside to help unblock the print core.
We have a few small scalpel knives that I can try using to cut the intersection between the filament and print core.
I'll try removing the Bowden after that and will update here.
Thanks Carla!
Carla_Birch 114
Edited by Carla_BirchLink to post
