Stop Filling the VOID!!!
Posted · Stop Filling the VOID!!!
Hey there.  I'm rather new to 3D printing.  I was wondering if I could get some help.
I design original files in Blender 2.79b, slice them in Cura 4.3.0, and send them to the printer.  ..At least, that is the plan.
What happens is that I put the exported STL into Cura and that's where things go wrong.
Problem 1) The 1cm*1cm*1cm cube gets enlarged to 1,000,000% bigger. So i resize it to approximately what it should be.
Problem 2) The voids inside the project that should be hollow, are completely filled in. (Example of a simple box attached)
Problem 3) I don't know if Cura is a resource hog or what, but every 3 seconds or so, it freezes my cursor in place for one second, then carries on.
I can't find any help online and I thought y'all could help me out here.  Ty
    Hi @Navitas,
    Problem 1)
    STL files do not define dimensional units, Cura expects all coordinates in mm. Easiest solution: change the units in Blender to mm
    In addition: the automatic scaling can be disabled in Cura preferences.
    Problem 2)
    There's indeed a Cura setting that can cause this: "Mesh Fixes -> Remove All Holes", but that's disabled by default.
    More likely: there are overlapping, missing or superfluous (inner) faces in your model. The function "merge by distance" in Blender does usually a good job for such simple models.
    Problem 3)
    I have no clue...
    Posted (edited) · Stop Filling the VOID!!!
    Thank you @tinkergnome for the reply.  It's closer to where I was before.
    P1) I've been putting the dimensions in millimetres already.
    P2) That has been plaguing ALL my projects.  I am careful to make sure the projects are all water tight as I build them.  The hole filling setting is probably the issue.
    P3) I think it's my PC not keeping up.
    Thank you again
    Edit: I verified Cura and the hole fill in option wasn't checked. 😞
    Edited by Navitas
    If you would share some of the stl-files - we can verify this 🙂
        • 24 replies
