1 hour ago, GregValiant said:Because you have ArcWelder enabled - Cura can't preview the Gcode file.
To clarify this a bit: Cura does not understand the G2/G3 Arc movements that are inserted by the ArcWelder plugin. The normal preview is not affected by this; in the normal preview, Cura just shows the original linear moves. The Arcs are only getting Welded when saving the gcode file. When you load the gcode back in, Cura will have a problem visualizing the moves.
GregValiant 698
Because you have ArcWelder enabled - Cura can't preview the Gcode file. I can read the Gcode into AutoCad but it doesn't show me were the Z seam is.
With the model loaded and Cura set up to slice - use the "File | Save Project" command and post the 3mf file.
