below is my startup code
; ABOVE this line is generated by cura
G90 ;absolute positioning
M82 ;absolute extrusion mode
G28 ;Home
Z_TILT_ADJUST ;true bed level
BED_MESH_CALIBRATE ;preform bed mesh
G92 E0
G28 ;Home
G92 E0
If Cura doesn't see any temperatures in the StartUp G-Code (and you currently don't have any) then it will add temperatures before the StartUp GCode to insure there is no Cold Extrusion. I'm not sure how it picked T0 to heat first. It may be the Initial Extruder (or Cura simply defaulted to T0). Since it picked T0 to be first then the other three extruders are only brought up to Standby Temperature for the material each has loaded.
Although T0 does heat first the M109 S215 line insures it is up to printing temperature prior to the StartUp Gcode being executed. The other three are not...they are brought up to Standby Temperature.
Which extruder do you need active for"...I have code to run after tool selection."? Do you need each extruder in turn up to print temperature? Are there prints you run with (for example) T1 and T3 active but with T0 and T2 disabled? (That combination would be tricky.)
Is the "...Code-After-Tool-Selection": Within the gcode file or are you calling a separate sub-file with M32 or something similar?
You could post a gcode file that you like and that contains the Code after Tool Selection. You might have to hand code parts of it.
Without knowing exactly what you want to happen (and when) I'm shooting in the dark.
GregValiant 696
I'll take a stab at this. It would be good if you would go to Machine Settings and copy your StartUp Gcode and paste it into a response here. Without it I have to guess (and that is never good).
It looks like your StartUp Gcode is configured to heat T0 to print temperature while heating T1, T2, and T3 to the material standby temperature. My guess is that T0 is going to print the skirt/brim/raft and so is the Initial Extruder.
You could alter the StartUp Gcode to insure that all are at printing temperature if that is what is required.
Right now you may have something like:
M104 S{material_standby_temperature} T1
if it was:
M104 S{material_print_temperature_layer_0} T1 ;then it would heat to print temperature, but it would not wait.
M109 S{material_print_temperature_layer_0} T1 ;would wait for it to get hot, but you would be waiting a while as each extruder would heat in turn.
If your power supply can handle it then...
M104 S{default_material_print_temperature} T0 ;Start to heat
M104 S{default_material_print_temperature} T1 ;Start to heat
M104 S{default_material_print_temperature} T2 ;Start to heat
M104 S{default_material_print_temperature} T3 ;Start to heat
M109 S{default_material_print_temperature} T0 ;Wait
M109 S{default_material_print_temperature} T1 ;Wait
M109 S{default_material_print_temperature} T2 ;Wait
M109 S{default_material_print_temperature} T3 ;Wait
would start to heat each hot end in turn, and then wait until each had reached printing temperature before continuing with the rest of the StartUp Gcode.
You could enter additional M104 lines to allow the hot ends to cool to the standby temperature and finish with the extruder that will be used first;
M104 S{material_standby_temperature} T0 ;Cool
M104 S{material_standby_temperature} T1 ;Cool
M104 S{material_standby_temperature} T2 ;Cool
M104 S{material_standby_temperature} T3 ;Cool
M109 S{material_print_temperature_layer_0} T{initial_extruder_nr} ;Heat the initial extruder
Without knowing what you have now I can't be sure but I think the above is in the ballpark. Wherever you end up, it won't be really simple.
