I guess the most elegant way would be using a dedicaded "USB port blocker" (physical lock with key).
Ideally, it would be nice if there was a way to disable it in software either from Digital Factory or from the settings menu on the device's screen that is already locked via PIN.
I wasn't aware of USB port blockers with keys so I'll have to give that a look.
I'd also thought about physically disconnecting the USB port from the mainboard but that seemed a little extreme. If we ever needed to use the USB port, for whatever reason, it would become a hassle.
Dim3nsioneer 551
Afaik the firewall only blocks internal network prints atm but not the USB port.
I would probably use a seal sticker on the front panel.
A more radical approach would be to disconnect the USB connector from the mainboard. For that you would have to open the bottom of your S3. You would do that in your own responsibility.
