Help. Slicer Create Random Wired Lines
nbvnbv
Posted · Help. Slicer Create Random Wired Lines
That could be an error in the model and Cura is getting confused about where the inside is.
If you post the STL or use "File | Save Project" and post the 3mf someone will look.
    Thanks For the resoponse
    I've added the 3mf File
    Thanks
    BFB_DualLetterBlocks-W-G.3mf
    That is just the model.  A project file would contain your printer, the model, and all your settings in Cura.
    I didn't find any problems with the model and using my E3Pro and my standard settings it looks good.  The screen shot is with the supports turned off.
    My bad , I've added the Project FileBFB_DualLetterBlocks-W-G.3mf
    I'm using this Printer:
    BFB Printer
    3 hours ago, nallath said:
    Seems like you are printing it with vase / spiralize mode. Disable that.
    spiralize mode is not Enabled. I use the Default Settings.
    Thanks
    Posted (edited) · Help. Slicer Create Random Wired Lines
    In your machine settings, the gcode flavour is set to 'bits from bytes' setting this to marlin gives a good slice.
    Not sure what firmware you have installed on your printer.
    Edited by obewan
    I do see that 'marlin' display it correctly
    But My Printer only Support  'bits from bytes'
    I don't know what to tell you.  I tried going to the 3dSystems website to see if there was some support there but I didn't have any luck.  It would appear that the BFB Rapman firmware is proprietary.  There were good reports about the BFB machines.  After 3DSystems bought BFB (2010) the reports went downhill.
    Did the printer come with a slicer program (3D Sprint??)? You might have to use their program.
    I guess Ill have to use the crappy old slicer program that came with the printer😥
    I really liked the Cura Program...
