Posted · Where do I find the settings for Draft Shields
I am only new to Cura, I am trying to find the setting for Draft Shields, I have activated the settings under the experimental heading. Now I want to set the shield distance/height and use the shield to assist with better prints.
Can anyone please help.
Thanking you in advance
Troy
    To the right of the Settings Search box is an icon with three lines on it.  Click on it and set the visibility to "All".  Your draft shield settings should all be grouped together in the Experimental section.
    Or just type "draft" in that area where it says "search settings".   To the left of that red circle above.
