Posted (edited) · Calculate Surface Area
Ha, I'll do you one better. It is already part of the Mesh Tools plugin. The "Analyse meshes" function will give you the surface area and volume, as well as the number of vertices and faces. I thought it only included the latter.
Edited by ahoeben
    5 minutes ago, azn90-z said:
    I can't access it after restarting the software
    Please elaborate. What do you mean by "I can't access it"?
    Read the documentation here:
    https://github.com/fieldOfView/Cura-MeshTools/#meshtools
    Edited by ahoeben
    Posted · Calculate Surface Area
    Thank you. But this gives only the number of vertices and faces, am I missing something?
    If you only get the number of vertices and faces, then the model is not "watertight" (manifold) according to the plugin. You can check for watertightness with the "Check models" function. For non-manifold models, the volume and surface-area are undefined. You may need to repair the model and reopen it.
    Do you mean repair the model in SolidWorks for example?
    I don't know if Solidworks has any mesh repair tools. I personally use 3d Builder (comes with Windows 10/11) or Mesh Mixer
