Have you check the nozzle temperature.
- 5 weeks later...
On 10/4/2022 at 7:21 AM, SimonGeorge said:Have you check the nozzle temperature.
No. I've used the standard profiles. Or how do you mean to check?
On 9/29/2022 at 7:43 AM, User100 said:Turns out that it was something wrong with the circuit board in the printhead. Making the two layer cooling fans not to work. It was also a bad soldering to one of the wires to the print core fan causing it not to work properly. The glass build plate got chipped, replaced it with a new one and now the prints sticks and releases as they should. So probably something wrong with the first build plate.
Talked to my local reseller support and they told me that it used to be a function in the maintenance menu of the printer to test if the layer cooling fans works. It's hard to check during printing. To bad that that function is removed now.
Also a worn AA0.4 nozzle making prints look terrible. New nozzle and cleaning filament to properly clean the nozzle. Hoping this will help.
User100 1
gr5 2,004
Thanks for the update. Sorry no one helped you here on the forum. Some topics just get lost - if you post and no one replies within 24 hours just add a second post saying something like "hello?".
