if this filament is PA based and/or the support is PVA, these strings might be related to moisture. You need to thoroughly dry your filaments and keep them dry, this will make the filament's flow more predictable and it will ooze less. you might also want to tune your retraction settings if not already.
best, Niklas
Carbon 23
You using a "Prime Tower"?
