Thanks a ton
Is there a guide on how to customize a calibration table. I have about a 20 deg offset in my HB temp in the useful range. I would like to heat to a series of targets, measure the actual temp at each target and adjust the table. I have lookwd into the tables a bit, but I dont have a sound understanding how they work. Maybe I'd be better served by a different table tgan the one I currently have selected. When I get home, Ill post which thermistor I have and request advice on the best table....
OK, I have the 100K thermistor sold by Ultimachine. #B57560G104F according to their sales page. The http://www.epcos.com/inf/50/db/ntc_09/Glass_enc_Sensors__B57560__G560__G1560.pdfthere doesn't have an exact match for that thermistor model. I think the part number may be a typo...
In Marlin, I am using the look-up table for sensor
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
#define TEMP_SENSOR_BED 1
Hi Mastory
If you look at your table for the number next to the temperature you are getting. Then find another table where that number gives the temperature you want.
Hope that makes sense.
That's the same thermistor as the OP. You want
#define TEMP_SENSOR_BED 3
Or just use robotfuzz marlin builder like I said to in my first post on this thread.
edit: Don't be confused with 56540G104F.
gr5 1,872
You want this one:
mendel-parts thermistor (4.7k pullup)
It matches the table you linked to perfectly.
http://marlinbuilder.robotfuzz.com/
