New custom build calibration cube
hhassan
Posted · New custom build calibration cube
I would like to consider myself not a newbie to 3D printing, but I have come across an issue that I have not managed to resolve.
My printer is an Anet A8 custom build with extrusion frame and linear rails. The extruder and housing design is taken from the Voron 2.
I am using Klipper as my choice of firmware and have dialled in all the setup parameters, such as extrusion, pid for print head temp, bed screw levelling and mesh bed levelling.
I started off printing a calibration cube and the results were disappointing. (please see attached photos)
The edges, in particular on one side of the Y axis, seem to be distorted, the opposite side seems fine, apart from the elephant foot at the base.
I have ensured there was no play at the print head and all belts were correctly tightened.
Can anyone shed some light on this?
    11 minutes ago, GregValiant said:
    The gcode looks fine and your settings seem reasonable (but I don't print ABS as I found it fussy and the fumes aren't good).
    How does your printer do with an easier material like PLA?
    Similar problem ☹️
    Posted (edited) · New custom build calibration cube
    Here is a different shape to try.  At least it will be something different to look at and it has different types of moves.  You can scale it in the Z to 5mm tall (or something) so you don't have to use as much filament.
    Printing it in vase mode is also an option.
    GVCalibration_Shape.stl
    Edited by GregValiant
    Thanks for sharing the file. I'll start the print in the next hour and share the results soon after
    Here are the results. Overall it printed well but there is still some visible distortion/shift on the X Axis. It only seems to impact sharp corners. This does not better than the calibration cube, but I did use the beta version of Cura 5 for this one. Not sure if that helped. Note: This is printed with ABS
    Edited by hhassan
    Those bad corners are at the same end.  They may be direction-of-travel specific.  You can try mirroring the model and see if the problem moves to a different corner(?).
    I'm sticking with a mechanical problem for now.  I'm not sure why or how, but it still looks like a problem in one axis.
    You can edit the gcode file with an M201 command to limit the Accel in either the X or Y.  I don't know what your settings for Acceleration are but something like "M201 X1000 Y250" before the first layer would limit the Y axis while leaving the X alone.  Then at layer 25 (or whatever) you could switch it with "M201 X250 Y1000" and see if there is a difference.  As I recall the Anet A8 is a bed slinger and on those types of machines (like my Ender 3 Pro) it can sometimes be an issue.  If I'm printing a tall skinny model I often limit the Y accel above about 150mm or the model can be toppled by the bed movement.
        • 24 replies
