5 hours ago, Dim3nsioneer said:Depending on the material it can also be used for the periodic print core cleaning (light PLA).
Thanks for reply, but the material is CPE for example or Tough PLA, and there are many meter of filament, more than one spool.
Usually I don't print with PLA, I prefer more technical material.
I think that one option could be, insert the pieces of filament after disconnect the material station directly in the infeeder in the back of the printer for print a small parts.
What do you think about?
Dim3nsioneer 551
