Hello and thank you,
I was working with Ultimaker support direct. The reseller Matterhackers has remained rather unavailable for some reason. The system is in fact more than a year old and is about 2 years total since installation. We've only used the second print core for some support material and very infrequently. I mainly pointed out the hours as the machine has not seen serious usage in my opinion. Not like my Prusa which printed over 850 headbands two summers ago when we were in the height of the pandemic. That machine was on non-stop 24 hours a day. I just am concerned that such an expensive part of the S5, the main board, which literally is not working very hard at all and is certainly not considered an expendable or wear item normally, would fail for no apparent reason.
I will attempt to contact fbrc8. Thank you,
Matt
gr5 1,837
Since you appear to be in USA, contact fbrc8.com. Is that who you are dealing with? Or are you dealing with your reseller? If you are working with your reseller then try emailing support@fbrc8.com. Include the above story and also your serial number. I'm not certain but likely they will give you a free replacement since your printer should still be under warranty on it I think? I'm a little confused. Maybe you printed only 53 days but you have had it for over a year?
Keep in mind that there's no way to show hours and meters on the machine - just each core. So you have to slide in each core and add them all up. Of course if you truly only used the same core in every job then that's not necessary.
