3 hours ago, ahoeben said:It seems that the model normals are throwing off Cura. The inner wall normals are reversed in relation to the outer wall normals.
It was the model's normals that were broken! I fixed the normals and tried re-printing it and it all worked out. Thank you!
1
Andrew_W 7
It appears as though the model you used has issues. I downloaded it and had the same outcome, I then opened it with 3D paint and saved it as a glb file and it seems to work OK?
ahoeben 1,763
