Qubea QD-1X is not printing
Posted (edited) · Qubea QD-1X is not printing
i have Qubea QD-1X printer.
With Kisslicer ( 5D absolute E Gcode ) everything is fine except there are 2 issues that bother me.
1. crowning gap, gap that i can see to on kisslices
photo : gap at the trunk corner behind the cabin.
2. visible seams
so i decided to give cura slicer a try but my printer just wont start print anything.
i copied the start and end gcode from kiss to cura.
it can heat the bed , heat the nozzle , home all axis. after that the nozzle is going down to print area but it wont print anything. just stay in the middle of the bed.
what Gcode flavour should i use ?
Tried marlin & reprap but still not working.
please help.
Thank you
Edited by sandisw
    i will post my startup gcode on Sunday because i forgot to bring my laptop with me.
    anyway these are the photos of the machine. i got this machine a couple months ago but it was built 7 years ago.
    Edited by sandisw
    • sandisw changed the title to Qubea QD-1X is not printing
    Posted · Qubea QD-1X is not printing
    OK.  On Sunday it is.
    They are Delta printers, and so probably Origin at Center.  Quebea is gone as you probably noticed.  Since you can get it/them to move and print with KissSlicer then they should work with Cura.
    Hi, Sorry for the late reply , i  just got home.
    This is the Start Gcode i got from the developer.
    ; [mm] mode
    G21
    ; absolute mode
    G90
    G28
    M42 P7 S100
    M190 S<BED>
    M42 P6 S160
    M42 P6 S255
    G28
    M109 S<TEMP>
    M42 P7 S255
    and this is the End Gcode
    M104 S0
    M140 S0
    M42 P6 S0
    M106 S0
    G28
    M42 P7 S0
    M400
    do you see anything wrong sir ?
    Some of the Start Gcode won't work with Cura.  I'm leaving in the M42 lines although at this point I don't think we know what is connected to those "pins" on your mainboard.
    The G28 in your ending gcode has to go.  It's never a good idea to drop the nozzle when there is a print on the bed.
    Copy and paste this in as your StartUp Gcode in Cura Machine Settings:
    ;Start Gcode
    G21 ;metric
    G90 ; absolute mode
    M82 ;absolute extrusion
    G28 ;Home all axes
    M42 P7 S100 ;set pin state of pin 7 to 100
    M190 S{material_bed_temperature_layer_0} ;heat the bed and wait for it
    M109 S{material_print_temperature_layer_0} ;heat the hot end and wait for it
    M42 P6 S160 ;set pin state of pin 6 to 160
    M42 P6 S255 ;set pin state of pin 6 to 255
    M106 S0 ;start with the layer cooling fan off.
    G28 ;auto-home again
    M42 P7 S255 ;set pin state of pin 7 to 255
    G1 F1800 Z10 ;move the nozzle up away from the build plate
    ;End of Start Gcode
    Copy and paste this in as your Ending Gcode
    ; Ending Gcode
    G91 ;Relative positioning
    G1 E-2 F2700 ;Retract a bit
    G1 E-2 Z0.2 F2400 ;Retract and raise Z
    G0 X5 Y5 F3000 ;Wipe out
    G0 Z10 ;Raise Z more
    G90 ;Absolute positioning
    G0 X0 Y{machine_depth} ;Present print
    M106 S0 ;Turn-off fan
    M104 S0 ;Turn-off hotend
    M140 S0 ;Turn-off bed
    M220 S100 ;reset feed rate to 100%
    M221 S100 ;reset flow rate to 100%
    M84 X Y E ;Disable all steppers but Z so the nozzle doesn't drift down
    ;The End
    The words/phrases in curly brackets are Cura keywords.  Cura will replace them with the actual values when the gcode is put together.  That's why "M109 S<TEMP>" didn't work.  Wrong word and no curly brackets.  So your hot end and bed didn't heat up.
    You can bring a simple model like a calibration cube into Cura.  Use the scale tool to make it 1mm tall.  Slice it and print the gcode to see how it goes.
    I copied and paste both the start and ending gcode. everything works perfectly !! I really appreciate your help. Thank you so much 😊
    this is the result of my 1st benchy printed with cura. overall is good, just need a slight tweaking.
    material : ABS
    Edited by sandisw
    TAAA_DAAA!
    Nice.  Don't bother trying to tweak that line on the hull that is at the height of the deck.  Can't be done.  I think doctoral thesis have been written on it.
