Hi there
I have also been trying to run 5 on my chromebook but dont know much about linux. When typing the ./Cura.... after installing it gives me this: [29473] Error loading Python lib '/tmp/.mount_UltimanU50jy/libpython3.10.so.1.0': dlopen: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.29' not found (required by /tmp/.mount_UltimanU50jy/libpython3.10.so.1.0)
I am running 4.13.1 without issues. I have also tried google but to no avail.
Can anyone please assist?
esopalumpa 6
On Debian Bookworm, the appimag claims that OpenGL is not available, which is – of course – wrong.
PyInstaller/loader/pyimod03_importers.py:495: DeprecationWarning: the imp module is deprecated i
n favour of importlib and slated for removal in Python 3.12; see the module's documentation for
alternative uses
libGL error: MESA-LOADER: failed to open radeonsi: /usr/lib/dri/radeonsi_dri.so: Kann die Shared
-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden (search paths /usr/lib/x86_64-
linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: radeonsi
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Kann die Shared-Obj
ect-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden (search paths /usr/lib/x86_64-linu
libGL error: failed to load driver: swrast
workaround:
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libstdc++.so.6 ./Ultimaker-Cura-5.0.0-linux.AppImage
Probably the build-system ultimaker uses for the AppImage is to old.
Edited by esopalumpaLink to post
