GregValiant 793
Yes, intermittent under-extrusion and some of it is very severe.
The #1 problem with under-extruding Enders is the plastic extruder arm. They all fail. 100% failure rate. They have been known to be delivered broken.
This is the underside of a failed arm.
The only fix for that is an all-aluminum extruder. They are available all over the place. I got the one for my Ender 3 Pro from Creality.
Have you calibrated your E-steps? It is necessary on Enders. When lines in the gcode file ask for filament the printer must deliver exactly the right amount of filament. The Extruder Steps/mm can be adjusted to insure what is asked for is what it gets. I'm sure CHEP has YouTube videos in his Filament Friday's series.
Another common problem on Enders (they all share the same hot end) is a gap developing between the back of the nozzle and the end of the bowden tube. Long retractions can pull molten plastic into that gap and it makes a sort of o-ring there and impedes the incoming filament.
The fix for that is to:
- Heat the hot end to around 200°.
- Pull out the filament.
- Remove the nozzle (carful - it's hot) using a correct wrench and NOT a pair of pliers.
- Remove the bowden tube from the fitting on the hot end.
- Shove a calibrated piece of coat hanger (about 1.5 to 1.6mm diameter) down through the heat exchanger and heat block (in a pinch you can use a 12" piece of filament but you have to move fast because the hot end is hot). I'm betting you will push out a plug of plastic.
- Cut about 5mm off of the end of the bowden tube using a decent single edge razor blade or equivalent. The cut must be as close to exactly square as you can get it.
- Put the nozzle back in and gently tighten it, then back it off 1/2 turn. The hot end must be at least 180° for this as any plastic that has gotten into the threads needs to be soft.
- Shove the newly cut bowden tube into the hot end and while holding it down against the back of the nozzle - put the locking clip back onto the fitting.
- Gently tighten the nozzle.
You should end up with the bowden making a decent seal to the back end of the nozzle. It should be good until the next time it happens. The bowden tube is a "consumable" and with every trimming it will keep getter shorter until it needs to be replaced.
With your model loaded (either one) and Cura set up ready to slice use the "File | Save Project" command. Post the 3mf file here and I'll take a look.
ChaosLord10 0
The pock marks on your filament guide may be caused by an extrusion issue. Meaning your filament may not have a nice even flow. This can have several causes. If your filament is not stored in a dry environment, it could have moisture in it. Another simple thing to check is your nozzle. If it is used or old, it may be causing under extrusion. More in depth fixes include calibrating your extrusion settings. I’d start with checking your nozzle, then get a full bed level. Can’t hurt to do it multiple times. Then pick a small print. Like a 6 sided die or something (you can find one on Thingiverse for free), and play with your temperature. Print a few times to find the right temperature for the material you are using. Also be sure to store your material in a dry environment. You can pick up a water tight bin and some of those “do not eat” silica packets at walmart. (I just save them whenever I have new PLA delivered). Anyway, that’s something to start with.
