On 7/26/2022 at 9:48 AM, GregValiant said:With the models loaded in Cura and ready to slice, use the "File | Save Project" command and then post the 3mf file here.
It almost looks like the mating surfaces of the models aren't flat. That would have been hard to do in Fusion, but something is going on.
I would suggest that you get rid of the locating pins as they are too easy to break off. Instead, put mating holes in that piece and glue in short pieces of wood dowels as the pins.
Thank you for your advice. I was messing with it for awhile and it actually appeared that while using circular holes for the air vents, the slicer was not getting the mesh correct up to a certain radius of the holes which was .35 mm. I changed the air vents to squares and everything worked fine after that. Thank you again for weighing in on my problem, I really appreciate it.
- 1
GregValiant 1,305
