I saw another user having the same problem on Reddit.
So I tried it with a similar model from Cults3D and also had a missing layer problem.
https://cults3d.com/en/3d-model/game/kobold-wizard-tabletop-miniature-m3dm
I checked it with the Mesh Tools plugin and it not report any problems with the model.
GregValiant 1,322
The model has errors in it but that doesn't mean it has to be scrapped. The errors might be because surfaces have their "normals" flipped or it might have open edges (non-watertight) or it might have holes (like appears to be going on one the ears). Cura can't figure out what is going on so those areas with errors can't slice.
You can go to the Cura MarketPlace and load the Mesh Tools plugin. It has analysis capability and a couple of repair utilities that are basic but work for a lot of models. It has other capabilities as well.
You can try to fix them in Blender (but I don't know Blender).
MS 3D Builder is bundled with Windows and has a good repair utility that runs automatically when you load a file.
There are also on-line STL repair utilities like https://formware.co/OnlineStlRepair.
Some files just can't be fixed though. At that point you would need to try again in CAD.
