Ultimaker 2+ and Klipper
Posted · Ultimaker 2+ and Klipper
Hey guys, I need help setting klipper for my UM2+.
I have installed klipper with ultimaker preset profile and had to adjust travel limits and Z steps, but looking good so far. The problem I found is hotend fan is not working (even if i heat extruder to 60C+). I don't know how to use gpio pins in klipper. For example I have this settings for part cooling fan and its working perfectly:
[fan]
pin: PH4
But that PH4 pin is PWM pin J14. How can I find relations for those pins (PH4 = J14)? My hotend fan is connected to J34, but I don't know how to make it running. Anyone have working printer.cfg for Ultimaker 2+?
    • 1 month later...
    • 6 months later...
    • 1 month later...
    Here's the config and macros for the Ultimaker 2+ with everything working. I've spent about the past year and a half developing and testing it. I have a different hotend so you may need to modify a few settings including the max build volume dimensions.
    Download the config files here
    https://drive.google.com/drive/folders/1OxPxsmWer21sLv70prQ4QPo8FjtGq7w_?usp=share_link
    • Heart 1
