There is no post processing in the extensions folder to open, If you look at the pictures you will see no no post processing in the extensions folder. It is not there with any printer not just the enders
Thank you for the reply
I see it now. I wonder if one of those other plugins you have installed over-wrote it or deleted it? Maybe @nallath can take a look tomorrow.
To diagnose this, we need your Cura.log. It can be found in the folder that opens when you go to Help -> Show configuration folder.
GregValiant 1,492
The post processors should be under "Extensions / Post Processing / Modify Gcodes" When the dialog opens select "Add a Script" and both Filament Change and Pause at Height should be in the list.
Be advised that it's possible that neither will work with your Ender as Creality seems to have made a hash of the firmware and M0, M25 and M600 may not pause the print.
Edited by GregValiantLink to post
