a known bug?
Hey @mrender
Thanks for the bump,I would've missed it otherwise. 🤛
And thanks for the report 👍
I just checked my Ultimaker S5 and I'm seeing the same.
I'll ask some around if it's a known issue.
thanks!
Update!
It's been found by one of the testers and I see that some efforts have been made to resolve it.
So I'm hoping that a fix can be included with other bugfixes in the next version of the firmware.
Fingers crossed 🤞
thanks for the update! yes fingers crossed.
- 4 months later...
Was there any update on this? Mine still does not display temperatures
Edited by Jhawk6553
Since this post, we haven't had a firmware release for the Ultimaker S5, only for the S7.
So keep a close eye on this page, or on your printer for updates.
Will a factory reset solve this?
18 hours ago, Jhawk6553 said:Was there any update on this? Mine still does not display temperatures
7.1.3, last in date, solve this issue, and had been stable so far :
IIRC, the temp issue was in a stable release : please UltiMaker, we already have so little information on this screen, Q-check that this kind of issue won't repeat on stable, that's not very professionnal for 6k€ machine 😕
Oh, and if it's possible to get the actual Z layer when printing, this is quite convenient and viewable on any other machine.
Edited by Dadkitess
Hey @Jhawk6553,
A factory reset will not resolve it, unfortunately.
A fix is in place, but it has not been released yet because there has not been a firmware release for the S5 since then.
I don't have any influence on how soon it will be released but I expect we don't have to wait much longer.
I apologize for the inconvenience.
1
Its all good. Thank you for the information!!
1 hour ago, Dadkitess said:7.1.3, last in date, solve this issue, and had been stable so far :
Yeah Im on 7.1.3 and the issue still is occurs unfortunately.
Oh ? Mine is fixed since the last release update I did and it is 7.1.3. Too bad, sorry 😕
- Solution
Update!
A new version of the firmware became available today that has a fix for this. 🎉
You can check your printer or you can download the latest version of the firmware here.
1
Fixed with the new firmware thanks!
1
mrender 27
..I should also say that i can see the current temp in the core setting page, can set a value there and see the current temp change.
