Tune screen not reading temps
mrender
Go to solution Solved by MariMakes,
Posted · Tune screen not reading temps
Hi I wonder if anyone has had this issue where the tune screen on S5 does not read the core temp when trying to set temp offset?
I can enter an offset value but get no feed back to tell me what the current and target values are.
thanks
    • 1 month later...
    Update!
    It's been found by one of the testers and I see that some efforts have been made to resolve it.
    So I'm hoping that a fix can be included with other bugfixes in the next version of the firmware.
    Fingers crossed 🤞
    thanks for the update! yes fingers crossed.
    Posted (edited) · Tune screen not reading temps
    Was there any update on this? Mine still does not display temperatures
    Edited by Jhawk6553
    Since this post, we haven't had a firmware release for the Ultimaker S5, only for the S7.
    So keep a close eye on this page, or on your printer for updates.
    https://support.makerbot.com/s/article/1667410781982
    Will a factory reset solve this?
    7.1.3, last in date, solve this issue, and had been stable so far :
    https://support.makerbot.com/s/article/1667337928766?_gl=1*zkl6k9*_ga*OTg2NzAzNDAwLjE2NzYzNzc0MzU.*_ga_JHX8W909G8*MTY3NjU1Mzk4OC4xMy4xLjE2NzY1NTQwNTEuMC4wLjA.
    IIRC, the temp issue was in a stable release : please UltiMaker, we already have so little information on this screen, Q-check that this kind of issue won't repeat on stable, that's not very professionnal for 6k€ machine 😕
    Oh, and if it's possible to get the actual Z layer when printing, this is quite convenient and viewable on any other machine.
    Edited by Dadkitess
    Hey @Jhawk6553,
    A factory reset will not resolve it, unfortunately.
    A fix is in place, but it has not been released yet because there has not been a firmware release for the S5 since then.
    I don't have any influence on how soon it will be released but I expect we don't have to wait much longer.
    I apologize for the inconvenience.
    Its all good. Thank you for the information!!
    Yeah Im on 7.1.3 and the issue still is occurs unfortunately.
    Oh ? Mine is fixed since the last release update I did and it is 7.1.3. Too bad, sorry 😕
    • Solution
    Update!
    A new version of the firmware became available today that has a fix for this. 🎉
    You can check your printer or you can download the latest version of the firmware here.
    • Heart 1
    Fixed with the new firmware thanks!
