It's the machine center 0,0 thing. The center of the plate is *not* 0,0 (it's roughly 116,116). So uncheck that. You probably didn't select an ultimaker2 as your machine so you may have other issues also.
Thank you guys.
Yes I am using Cura and yes I did select Ultimaker 2.
Yes I had checked the machine center box, thanks again.
IRobertI 521
Are you using cura to slice the model? Did you choose "Ultimaker2" as the machine type? Did you accidentally check "Machine center 0,0" in the machine settings?
