Thanks again @Masterdark for taking the effort to reply and help out! I have reset the printer to factory settings but unfortunately (in most cases this is wanted off course 😉 ) the materials aren't removed.
So now I will try to guess what material it could be and will try to delete those. I'm also going to make a support request for this at Ultimaker. I will post here what comes out.....
Masterdark 7
@dennismosterd
Since several people have the problem and there are several posts about it, I think that the problem is known and will hopefully be fixed soon.
Since the GUID should be unique, but this is not the case when exporting from Cura, an adjustment in Cura and the printer firmware will probably be necessary.
Another note for the API.
Before material can be deleted or added via API, a user must be registered.
To do this, use the command POST/auth/request via the API.
Make any entries in the application and user fields.
After the request has been confirmed with the <Try it out> button, the request must be confirmed on the printer display.
The API then returns an object with the properties <id> and <key>, see screenshot.
To delete or add material, the <id> must be used as the user and the <key> as the password.
