UM3 Freezes Mid-Print
nusslucas
Posted · UM3 Freezes Mid-Print
My UM3 freezes during mid-print at a random time and a random spot on the print model.
The printing nozzle is then melted on to the part itself and the printhead stand still over it. (As on the picture)
On the display the remaining time is shown but is frozen to the time the freeze appeared.
The control wheel ist still responsive and you can go through the different menu options but nothing happens when you click on it.
To clean out the printer and work with it again it is then needed to power cycle the printer and then it is responsive again.
Did anybody have a similiar problem or knows how to solve this ?
Logfiles of the last time are attached to the post.
P.S.: Alredy tried different printing methods (USB,Network,Cloud), different models, factory reseting and firmware restoration.
dmesg.log ultimakersystem-ccbdd3004478.5.3.0.boot0.log ultimakersystem-ccbdd3004478.5.3.0.boot-1.log
    • 1 month later...
