GregValiant 1,251
The Cura X-Ray view shows problems at the ends of the ridges. Maybe they don't go all the way to the wall and their ends are open???
I used Mesh Mixer to repair it as it was a bit beyond the Cura Mesh Tools plugin. MS 3D Builder is pretty good as well.
The repaired model is on the right.
And it's obvious that @Torgeir took typing in school as he is way faster than me.
Edited by GregValiant- 1
Torgeir 242
Hi @JOMS,
There is nothing wrong with your model.
However, to be able to help you, you must save your model as a "Project" file and attach the file in here.
This will show the settings you're using -then someone might be able to help you.
Thanks
Torgeir
