DivingDuck 105
The best way to overcome these problems is to create a folder that includes all files needed including the .stl file and a little batch file for running the slicer engine.
Looking on your errors there are missing:
ultimaker2_extruder_0.def.json,
in addition you need:
ultimaker.def.json,
fdmextruder.def.json
Here is an litte example, extract the folder Test to your Desktop and run batch file SliceUM2.bat in cmd window:
- 1
MariMakes 203
Hey @BiLeVi,
Welcome to the Ultimaker Community 🎉
Personallly I'm not very skilled with running from the engine command line, and most of the Cura Developers can be found on the Github https://github.com/Ultimaker/Cura
But I can ask someone from the team to take a look for you. 🤞
