Polymaker PA12-CF Nylon
golferbrady
Posted · Polymaker PA12-CF Nylon
Hey @golferbrady,
Welcome to the Ultimaker Community 🎉
You can install this material from the marketplace in Cura.
https://marketplace.ultimaker.com/app/cura/materials/Nicolas_Tokotuu/PolyMidePA12CF
If your printer and Cura are connected over the internet your material will end up in the printer.
However @dxp is correct, this profile is made for a CC 0.6 or CC 0.4 core so it won't work without it.
You can get it for here or at other Ultimaker resellers.
