Did you try tree support?
There is also a plug-in created by a member of the communtity to add meshes to create support.
You can donwload it here: https://marketplace.ultimaker.com/app/cura/plugins/5axes/CustomSupportCylinder
Attached is the stl file.
I found the same stl file but with tree support built in. The tree support didnt do too well. Although I guess it could have been a bed leveling issue, but I havent had any issues with any of my other prints and I did recheck the bed all was fine.
Sorry about that, I am printing on a Ender 3 Pro.
Personally I would print it with PVA as support, but I'm guessing you don't have dual extrusion.
My best bet would be to try the tree support, or modeling the support your self.
An other option would be to print the arms separate and glue them on.
@MariMakes This is work correct? In the sense that where the blocks are placed supports shouldnt be built there correct?
- Solution
Hey @Beretta031,
I believe what you are seeing is expected.
Support generates in the areas that are red if you look at the bottom of the model.
If a support blocker is placed over these red ares, these areas will not be supported.
In your case support is generated for the hands and not for the trophee handles.
You can read more about it here.
https://support.ultimaker.com/hc/en-us/articles/360012869379-How-to-block-support-generation-in-Ultimaker-Cura
I printed the tree support mentioned above and it came out great.
Thank you so much for your help. I will be giving it a whurl tomorrow.
Looks good mate
I'll post the final product soon!
dsp 18
Can you post the stl file so we can tinker with the settings?
I'm thinkin tree support and only from baseplate but without a model I can't test it for you
