I can not find a way to change the cost of material either , using any material for example generic pla. earlier versions of cura, it was easy to fill this in or modify it. Now it is not allowing changes. PLease inform of the method to be used to modify this value
Hey @dirtyoledog,
Welcome to the Ultimaker Community 🎉
If you go to your material in Preferences, Materials
You can change the Filament Cost and Filament Weight.
If you slice with that material, it shows up in your estimation.
Is this the information you are looking for?
Hey @HavanaMoss,
Can you check for me if you can alter settings in your material once you clicked Activate after clicking the hamburger in the top right?
Hi! Thank's for your answer!
Unfortunately not, i can't. However i found that i have to duplicate the profile and edit the new one.
I think that cura doesn't want to let the user change the default value on the material profile provided by the software. If you want to change some value you have to create a custom profile from the default one. Is this the normal procedure?
Hey @HavanaMoss,
You are correct. You cannot change the default materials, you'll have to duplicate them first.
If you duplicate the material, please take care that you make the Material Type match any of the generic material types exactly. (so no PLA+ or TPU)
A little birdy told met that you also cannot change a material if it's active in another printer. So if you have multiple printers loaded in Cura, make sure that they do not have the material you want to edit active. That could maybe also be the cause of your trouble.
Good luck and happy printing!
- 1
MariMakes 199
Hey @mulawi
I split of your issue from the old thread because I'm not sure if it's related.
Can you share some screenshots of what you are seeing?
Are you trying to change the materials that come with Cura like Generic or Ultimaker materials or did you create a new material?
