You want to repeat a layer or two so it prints the exact same thing 2 or 3 things without the Z moving?
Oh wait!
You want it to print exactly normal except the Z axis doesn't move for 2 layers. Well that's pretty easy to just do it by hand in the gcode. Search the gcode file for the letter Z. Once you get past the first few there is only one Z in the file per layer and it's the height. Just take a look.
Unless you have zhop enabled. If you do then that's unfortunate as there could be tens of thousands of Z's in there.
But most of the time there is only one per layer so if you have 50 layers you only have to edit at most 50 numbers/heights.
Take a look at the gcode! It's not that complicated.
Another trick is to use G92 gcode. Here is a typical layer change - note the "Z 1.2" which means move the Z axis to 1.2mm such that the nozzle is 1.2mm from the bed.
;LAYER:6
G0 X119.348 Y137.166 Z1.2
What you can do is fool the printer telling it "hey you are already there" with the G92 command so:
;LAYER:6
G92 Z1.2
The G92 says: Hey I know you thought the Z was at 1.0mm but pretend it's actually at 1.2mm. Already there. So then when the printer sees the command to go to 1.2mm it will just ignore it.
Just add the G92 for the layers where you want Z not to move. The bonus of this trick is it will work even if you have z hop enabled (but in that case don't search for Z as it will take forever, instead search for "LAYER").
Once you stop adding G92 gcodes the printer will continue moving up but only in small increments (it won't suddenly jump up for every layer you "locked").
3
gr5 2,192
Oh wait!
gr5 2,192
;LAYER:6 G0 X119.348 Y137.166 Z1.2
;LAYER:6 G92 Z1.2 G0 X119.348 Y137.166 Z1.2
