Here's the Cura project file.
Here's an analogy to think about: you are trying to draw fine lines with a fat sharpy.
There are limits to how thin you can print with a 0.4mm nozzle. Here is some more info:
https://github.com/Ghostkeeper/SettingsGuide/blob/master/resources/articles/troubleshooting/missing_parts.md#thin-parts (the "thin parts" section)
Edited by ahoeben
I'll just drop back to using VoxelMaker, which slices it just fine.
GregValiant 1,330
There are a couple of problems there. The thin sections of the letters are to thin to slice (the L's and E in particular).
Load the model and set Cura up to slice. Use the "File | Save Project" command to create a 3mf file and post the 3mf file here.
