@MariMakes I also don't usually use coasting, but this is a very thin print with small clearances and moving parts and the small blobs that formed at retractions were enough to make it not work. Coasting is supposed to solve this issue so I think getting it to work would help. I tried changing other settings but that didn't help enough so I need coasting.
Attached is the project file in case you need it.
Edited by Mike2481632
MariMakes 198
Hey @Mike2481632,
Welcome to the Ultimaker Community 🎉
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project
Personally I don't often use the coasting settings.
Did you try printing it without the coasting settings? What was the result?
