Hi GregValiant, thank you for your response, that makes sense. I am finding that I get underextrusion if I reduce temperature with the ultimaker, so I have not been able to drop down to 225, using polymaker PETG. I have noted that there are some nozzles with extended tips so as to put more distance between the body of the nozzle and the print but have not seriously explored those. Perhaps I should look more carefully at its tendency to underextrude and try harder to reduce the nozzle temp.
GregValiant 1,330
I forgot to mention that I print PETG at 105% to 107% flow. It is the same diameter as my PLA so it is likely a material property thing. Could be my cooler print temp as well. I have say the quality and finish of the prints is excellent, they just take longer.
Yes there is often a tradeoff of speed vs quality bu it's not a linear slope is it? Thank you for that input I'll experiment.
- 1 month later...
I also print PET (or PETG, I don't know) at the lower edge of its temp range, sometimes below its recommended range, and at far lower speeds than PLA.
When molten, PLA becomes sort of yoghurt and flows easily, but PET rather stays like soft, rubbery chewing gum, it does not like to flow well. PLA bridges well, but PET tends to snap and fold back onto itself, so instead of a nice bridge I often get a sort of "grapes" accumulating on the edges.
And as said before, it tends to accumulate on the nozzle, causing a thick blob that slowly sags onto the print every so many minutes. The blob gets brown due to decomposing, if the temp is too high.
I use no cooling fan, and have no problems with warping.
I find PET is best for things that need a little bit of flexibility, like snap-fit mechanisms. But it is not stronger than PLA, only more flexible, and has a bit less creep under load. And it can go up to 70°C where PLA can only go to 50°C, and under load even not that. So PET is suitable for use in a car, PLA not (don't ask how I know). When printing without cooling fan, layer adhesion is good, I have no separation.
Clarity in transparent PET improves a lot when printing slow and in thin layers, indicating that there is far less air entrapped between the extruded sausages.
All bad effects are minimised when printing cooler, slower, and in thinner layers.
A few examples:
Ruler is in cm an mm:
PET can be chemically smoothed with dichloromethane easier than PLA, and it does not seem to dry out in het months after treatment, contrary to PLA that tends to develop microcracks. Both parts are identical, but one is smoothed to remove layer lines: much more hygienic for use in hospitals, easier to clean.
Transparent PET printed at different speeds and layer thicknesses: blocks are 20x10x10mm. Printed at 0.4, 0.3, 0.2, 0.1 and 0.06mm layers, top row at 50mm/s, bottom row at 10mm/s if I remember well. The yellowish discoloration is from sitting long in the nozzle at very slow speeds: it begins to decompose. Temp mostly is 215°C, except the thickest layers at 225°C, and the thinnest at 200 or 205°C. The watermark with my name is sitting halfway inside the block, it's hollow text, and only readable at low speeds and thin layers.
1
GregValiant 1,330
I've printed quite a bit of PETG on my Ender. I found that printing as cool as I can get away with and at 35mm/sec is a good thing. I'll print PLA at up to 150 but PETG is a lot better when put down slow.
I typically print PETG at 225° with the bed at 80°. A lot of models require elephant ears to keep them from warping off the bed.
I also raise my retraction distance to 6.5 (PLA at 5.5) and set the retract/prime speeds to 25.
A lot of the stringing can happen because PETG tends to collect on the nozzle a lot more than PLA. When that blob on the outside of the nozzle gets to a certain size it slides down, touches the print, and then is like a second extruder that just makes a mess.
