Do you happen to have the plugin "Startup Optimizer" enabled in the MarketPlace? It simplifies the loading of Cura (to speed it up) and I believe one of the things it does is cleanup the number of printers available. If it is enabled then disable it and restart Cura and the printers should show up.
It is better to use the "Extensions -> Start optimsier -> Restore all configuration files" option before disabling the plugin. Otherwise, if you at some point re-enable the plugin, your new printer configuration may break (because its definitions and profiles are once again not loaded).
GregValiant 1,492
ahoeben 2,047
Only when you tell it to though...
tysonwald 0
Thanks! I just deleted and reinstalled. Didn't install any plugins and now it is working. thank you!
