I'm also curious what units the XY calibration numbers represent because it doesn't seem like they are a mm value like on many other printers (usually 0.1mm increments).
Is there a way to manually view or edit the offset in mm units?
Yes you can edit the offset directly without doing the calibration and I believe when you do that it shows you the old values.
gr5 2,331
14 is a lot. You could try zero. Or do the XY calibration. Doing the XY calibration is the proper way. Do you have the calibration sheet? After it lays down material from both cores you are supposed to remove the glass and place on a piece of paper so you know which lines are +1,+2,+3, etc for each axis.
See these instructions
https://support.makerbot.com/s/article/1667410778876?utm_id=UMa1709000000F48h
