When I was printing with PP, I put packaging tape (PP based) on the entire print surface. The printed object fuse with the tape and give a good bonding.
2
When I print with PP, I set Adhesion on (Brim) and use a glue (Magigoo for PP) much. These can give a good bonding.
Recently I make small size grooves near bottom corners .
These grooves prevent parts from bending.
MOTO 1
bumping this topic. hope you found some answers.
do you have the airfilter as well?
having the same problem, same machine.
did have some good results but from a set of 7, only 1 came out real good. very inconsistent.
