You could try printing it in another orientation (eg standing upright instead of flat on the bed), but that will affect the strength of the part.
16 minutes ago, ahoeben said:You could try printing it in another orientation (eg standing upright instead of flat on the bed), but that will affect the strength of the part.
Thanks. Not an option for this one I'm afraid. But...got mostly rid of it by changing to a Connect. Guess it uses different stepper drivers 😀
GregValiant 1,320
That is how compound curves will print. It is a function of the STL resolution, layer height, and how Cura interprets the changing "curvature" layer-by-layer. The phenomenon occurs because there isn't really a curve there but rather a number of triangular facets that approximate a curve.
If you open the model file in a program like MS 3D Builder and look at how the triangles are laid out you will see what is going on. Cura slices through the edge lines of the triangles that are approximating the curve so the line segments change layer-by-layer and give that characteristic "woodgrain" pattern.
kris 29
Thanks for the reply. That's also what I thought.
I also did a high res STL and printed it. Did not improve the behavior. Guess it is a hardware thing.
UM2C turns out to be a different story.
