Material stuck in print core after each print
LXXXIII
  • 1 month later...
Posted · Material stuck in print core after each print
It needs to be 60C. Before this it first pulls a thin neck at printing temperature, before it cools down to 60C to cleanly break this thin neck. This forms a proper filament tip that can move up and down the material handling system.
    Ah!  So there are two retractions.  One at a higher temp.  One at 60C.  It sounds like LXXIII has an issue with the filament stuck in the print core somewhere.  I'd get a new printcore.
        • 26 replies
