Dustin I doubt it's the version of Cura.
LXXXIII - there are many possible causes. The most common by far is that the front fan stopped working. The printer doesn't have a way of knowing this. The 2 symptoms is low or failed extrusion after 5 to 20 minutes of printing and having trouble getting the filament out of the print core after it has cooled.
So heat either printcore to 100C and as it passes around 40C the fan should start spinning. Open the front cover to make sure it really is spinning.
If that works then it's most likely a problem with the printcore. The teflon inside after a lot of use can have issues where there is now a space for the filament to expand into, then cool/harden, then get stuck. Printcores are considered expendable (like filament) and should be replaced occasionally.
Dustin 84
Sorry to hear you are having issues.
I would recommend updating your version of Cura.
Additionally, can you confirm the exact firmware version number you're on?
Doing a quick glance at the Support Knowledge Base also notes printing with materials such as PLA with a CC core is considered experimental. So, your results may vary considerably.
CC print core compatibility (makerbot.com)
Print core and printer compatibility (makerbot.com)
