GregValiant 1,492
Since the Arachne Engine was rolled into Cura there are additional settings for walls. Some settings are specific to UltiMaker printers and others were made defaults in an effort to increase accuracy. They aren't always what you want.
Here is the model. The points are the problem as "knife" edges always are.
This is the model sliced with your settings.
The "Outer Wall Inset" at 0.025 is hurting the slice because it makes the "points" 0.05 narrower. That coupled with your "Line Width" at 0.4 is keeping the nozzle from getting to the end of the points in an "Out and Back" move. The "Wall Transition Angle" at 10° is also hurting the slice. With those settings Cura is calculating the move as "Out - Travel - Continue". That is indicated by the white spots showing where the extrusion starts at the very tip of the point. Not good.
This is with Outer Wall Inset = 0, Line Width = 0.35, and the Wall Transition Angle = 5.0°. With those settings Cura calculates the move as a sweep out to the point and then a continuation back along the other wall. There is no longer a "Start-Stop" at the end of the points.
This behavior can also be noted if you try to print something like a hair comb. Each tine of the comb needs to be an "Out and Back" extrusion rather than "Extrude Out Tine 1 - Travel over to Tine 2 - Extrude Back Tine 2" moves which leads to stringing and half the tines get welded together at the tips.
1
1
1
64Pacific 2
I am struggling with the exact same issues and have yet to figure out a way to resolve it - it seems that whenever there is a start (which is what I believe the white squares represent) I get a blob of plastic and holes in my models. Like you I have noticed that older versions printed much nicer than than the current version (5.2). Lately I have been throwing more prints in the trash than anything. Currently attempting a firmware update with the hope that this resolves the issue...
MariMakes 208
Hey @2go,
Ah, this seems to be a bunch of wedges, the Variable Linewidth Engine in Cura 5.x sometimes struggles with that.
There are settings that you can change to improve this behavior.
You can read more about them here: https://support.ultimaker.com/hc/en-us/articles/4792077687068
The white squares indeed indicate a layerstart like the layerstart/zseam.
Looking from your screenshot I think it might also be worth checking your resolution settings. 🤔
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
2go 7
Hello @MariMakes,
Thank you for your answer. Sure, I've attached a test STL and the project file. Below is the screenshot of the best result I was able to achieve on my own with Cura 5.x, while Cura 3.x handles this inner edge flawlessly.
Any help would be highly appreciated. I'll go and read the article you've linked now. Thank you.
UM2_test.3mf test.stl
Edited by 2goLink to post
