Thanks for your feedback, I did not know about nGen filament, unfortunately it's not available on RSPro which is my specific demand, otherwise I already have a good set of material with my initial supplier.
I've already asked on the French Forum but not as many answers as here and the question is quite generic 🙂
gr5 2,024
The hotter the filament the harder it is to print. The harder it is to keep the part from warping off the print bed, the more it helps to enclose the printer and the more you have to experiment with the fan (some printers are full power at 10% - no different from 100% and only at values lower than 10% does the fan start to slow down).
nGen is super easy to print - like PLA. Nothing else is as easy as PLA. nGen can only go up to similar temps as petg - around 70C if I remember right before it becomes a bit soft (like hard clay).
ABS is a good filament, similar to PLA tough and it stays strong up to about 99C. It's used I believe in car dashboards which often get well above 50C. It smells horrible when printing and the fumes are probably bad for you. It takes a while to get good at printing it - easily your first 50 prints will be weak. You have to have high temps to get good layer bonding (low fan, enclosed printer) but you probably won't realize how bad your layer bonding is on the first 10 prints. You want to keep the bed well above 99C or the ABS will warp off the glass. I like 110C but it takes so long to get up to that temp and you should enclose the printer. But it's worth it. I hate ABS for it's smell.
Nylon. I love nylon. Easier to print than ABS but not a lot easier. Not stinky either. I get the natural nylon and then dye it. It sounds like extra work but Nylon is so easy to dye. I print a lot of parts in Nylon but because it is more flexible. Not because of it's temperature abilities (it can handle 100C fine but will be more flexible - but it will spring back to original shape even when at 100C). It may be too flexible for you but you can get varying stiffness (modulus).
As far as suppliers, it looks like you are in France so post to the french speaking part of this forum.
