Hi @TonyCOD,
Have a look at those two pictures, without and with bottom.
Upload this below project file and open the original project with an UM2E+ printer, then you see all the "important" settings.
First my pictures:
Here's the next:
The project file. Check this out and you'll see all the settings.
UM2E_Test_Step_Clean_h_0_15.3mf
(Note; My UM2E+ have a double density of a standard UM2+/E+ -not to be printed with a standard printer)
This note might not be a problem since this is not a gcode generated by me.
Thanks
Torgeir
Edited by Torgeir
Added note.
Hi @TonyCOD
What printer are you using?
You can use the printer you want, accepting the settings I'm using on the Ultimaker.
Then fine tune, for filament nozzle etc.. If needed.
Thanks
Torgeir
GregValiant 1,319
I like the SmartAvionics fork for Spiralize. His builds are based on the 4.x version of Cura.
1
14 hours ago, Torgeir said:Hi @TonyCOD
Thanks
Torgeir
i opened your project but was still showing the unintended travel moves. by the way i do not want to print that particular model, i was just trying to understand
3 hours ago, Torgeir said:
ah ok, i still have the 5.13, rolling back
Torgeir 248
Hi @TonyCOD,
Yes, ColorFabb LW-PLA is just the filament I'm using for wing foils..
The the last file you put in here, the step file, is converted to stl and can be printed by Cura in spiralize mode.
You need just to put in the right parameters for spiralize without bottom, or with bottom ofc. no top.
This is with Cura 4.13.1.
It is here:UM2E_Test_Step_Clean_h_0_1.stl
Have a look into this tread:
Thanks
Torgeir
